Idle too fast on my te20
Tommy L
06-11-2005 19:55:21
I don't have a manual and have been trying to adjust the idle. It runs pretty fast when the throttle is clear back. Shouldn't it be around 3 to 4 hundred rpms? It sounds like about 9 hundred or a thousand rpms. I hope nothing is wrong with the governor, it seems to be working.
Thanks,
Tommy L
John(UK)
06-13-2005 14:54:14
 Re: Idle too fast on my te20 in reply to Tommy L, 06-11-2005 19:55:21
The idle speed should be 400 - 450 rpm on most Ferguson engines, you don't say what engine or tractor you have. It could just be that the throttle linkage has slipped on the long rod or that the Governor does require adjusting. If you need more help and instructions on how to set it up, email me at fergusontractors at tiscali dot co dot uk....tell me what tractor and engine you have.
