Steering Arm Bushings For TO-20
Bowser
06-02-2000 20:18:35
I need (2) steering arm bushings (the part number listed in the Ferguson T-20 Parts Manual is TO-3517)I have tried Massey-Ferguson Dealers and
several parts dealers on the internet and have not
had any luck in locating them.Does anyone know of
a source where they can be purchased? Any information will be greatly appreciated.Thanks.
Paul in NM
06-04-2000 08:30:25
 Re: Steering Arm Bushings For TO-20 in reply to Bowser , 06-02-2000 20:18:35
Bowser - Ford N bushings will not work. The part number you are using is obsolete. The MF number for the outer bushing is 180 363 M1 (size is 1-5/16 x 1-7/16 x 1-13/64). The inner bushing is 195 783 M1 (size is 1-1/8 x 1-7/16 x 1-1/8). When I was rebuilding my TO-30, I had to buy the bushings from a bearing house. If you can get the inner and outer dimensions, you can saw off the extra length if they don't have one the exact length. Good luck!
Paul
Bowser (VA)
06-04-2000 14:16:18
 Re: Re: Steering Arm Bushings For TO-20 in reply to Paul in NM, 06-04-2000 08:30:25
Paul,I appreciate the information.I will go to a
bearing supply to see if they have bushings that match the dimensions that you listed.I thank you
for the information.Bowser
Arnold Bruns
06-03-2000 10:59:22
There were several parts of the TO-20 that would inter-change with Ford tractors of the same era. Not knowing where you live, I would suggest contacting a Massey-Ferguson dealer in the Midwest. There are a few of the old Fergusons still being used in that part of the country. There is a dealer in Higginsville, MO that has a TO-30 they have restored and a parts distributorship in Kansas City, MO.
