cylinder sleeve
fergieboy
06-10-2005 21:37:51
Can a engine be re sleeved with out removing the engine,and the crank installed?
John(UK)
06-11-2005 10:29:37
 Re: cylinder sleeve in reply to fergieboy, 06-10-2005 21:37:51
you can re sleeve the engine on a carburettor engine and a 20c & 23c diesel without removing the engine. Regarding the crank...do you mean can you do this with the crank installed....YES. Take care with all the crud in the cylinder block though on the carb. engines or it will get into the oil-ways on the crank, you need to tape the journals while you do the sleeves to keep them clean and wash out the block afterwards. You didn't say what engine you had so we can't give you more details.
fergieboy
06-11-2005 10:50:44
 Re: cylinder sleeve in reply to John(UK), 06-11-2005 10:29:37
1954 to-30
