TEA20-85-noisy clutch-help!
Fabien
06-10-2005 07:03:38
My 1954 Fergy has developped what I believe is a clutch release bearing problem, since the latter squeals every time I step on the clutch pedal. Is there a way of lubrcating the realease bearing without disassembly? Any help on this matter would be greatly appreciated. Thank you.
Fabien.
John(UK)
06-11-2005 10:41:37
 Re: TEA20-85-noisy clutch-help! in reply to Fabien, 06-10-2005 07:03:38
You need to split it, sorry. Don't forget to change the pilot bearing in the centre of the flywheel as this can give you squealing noises too and other things.
Jim W
06-13-2005 06:49:30
 TEA20-85-noisy clutch - now pilot bearing in reply to John(UK), 06-11-2005 10:41:37
John,
As I recall that pilot bearing is the same one as used in the water pump, which is to say, NLA.
What do people do, use a bushing instead?
I just happened to have a NOS one by a stroke of luck so was able to replace it while my own TEA was split but have been wondering what to do if I ever need to do it again - and would like to be able to fix water pumps too.
Jim
John(UK)
06-13-2005 09:55:36
 Re: TEA20-85-noisy clutch - now pilot bearing in reply to Jim W, 06-13-2005 06:49:30
Don"t think it is the same bearing Jim but you could be right, there is nothing ringing any bells with me(yet). The Pilot bearing is still available though, it was MF part number 828123M1 and the Sparex part number is S40734, this same bearing fits the TO tractors too. It could be still available as an MF part but Sparex do have it. Let me know about that water pump bearing if you do find out please.
Jim W
06-13-2005 11:42:51
 Re: TEA20-85- pilot/water pump bearing in reply to John(UK), 06-13-2005 09:55:36
Hi John,
Someone in the Triumph community has informed me that the water pump bearings (used in both the TR2-4 and TEA) are MF p/n 825-375 M1, which at least is a different MF #.
Yet I feel quite sure I put a w/p bearing in that pilot bearing spot. Maybe it's just a different width. If you can find the water pump bearings from any source, I'll take a dozen.
Thanks,
Jim
John(UK)
06-13-2005 14:18:03
 Re: TEA20-85- pilot/water pump bearing in reply to Jim W, 06-13-2005 11:42:51
I am making enquiries right now about those bearings as they should be available to you. Will send the info as soon as I get word back, maybe Tuesday.
toolman
06-10-2005 14:12:20
i been living with that noise for a couple of years now, haven,t had the time to split and put in a new on , when i do i,ll be doing clutch, seals the works.
Jim W
06-10-2005 11:14:52
Sorry no access without splitting the old girl.
Jim
