fergy position control
Iain Gibson
06-07-2005 21:43:47
I recieved some plans kindly from a member of this site to make a position control device for a te20. It works great!! The only comment I have is that the angled side of the 3x2 steel is facing the wrong way, the holes where it bolts to the shaft are in the wrong position about the axis.
Is this a difference between tractors TO vs TE maybe?
Jeff-oh
06-13-2005 10:41:28
 Re: fergy position control in reply to Iain Gibson, 06-07-2005 21:43:47
Iain,
There should be no difference between the two. That said. There is nothing sacrad about the angle. It is only there to provide for the position stop. If you need to modify the slope or make it square then that will work too.
Jeff
John(UK)
06-13-2005 15:01:55
 Re: fergy position control in reply to Jeff-oh, 06-13-2005 10:41:28
Sorry Jeff I should have remembered it was you who posted that.
John(UK)
06-11-2005 10:47:45
There is NO difference in the TE and TO in this instance. If I remember correctly the reply to this same question from the guy who originally posted it was that it wont make any difference which way the holes where, now what he meant by that I don't know, maybe you can work that part out when you look at the kit.
