Vertical exhaust
Logger Jack
06-01-2005 20:14:02
I am restoring the TO-20 I have had for 30 years and notice in the parts shops, there are two styles of exhaust available - the usual under the rear axel type and also a vertical. I have seen pictures of Fergusons with vertical exhaust on the right side center of the hood, but they may have been European TE-20 models. Anyone know if the vertical can be used on a TO-20 or does it need a different manifold?
backhoejoe
06-02-2005 10:03:50
 Re: Vertical exhaust in reply to Logger Jack, 06-01-2005 20:14:02
I put one on my TO-30 with out a problem. As long as the verticle exhaust has the same type of flared end and clamp you should be fine.The one i got came with a suport and clapmed on the pipewith a muffler clamp and if you do it right you can fit teh other end to the top generator bracket.
Vince (FR)
06-02-2005 03:35:29
look at this page!
Link
Ray,IN
06-02-2005 20:48:59
 Re: Vertical exhaust in reply to Vince (FR) , 06-02-2005 03:35:29
They are available from walts tractors dot com or davis tractor dot com.
