New TO-20
mgross
05-31-2005 09:28:51
third party image
Yesterday I brought home this TO-20 #12,669. Lovely machine that runs very nice. However... someone left the ignition on and burnt up the coil and primary wiring on the first day. sigh. It's had a 12v conversion, so I assume a standard 12v coil is the replacement? I also found the battery carrier is somewhat rusted and the battery is secured with a bungee-cord! Can anyone suggest a replacement/alternate way to better secure the battery? This is my first outing with a tractor, my other old vehicles all have only two wheels.
thanks - mark
Jerry/MT
06-02-2005 18:13:21
 Re: New TO-20 in reply to mgross, 05-31-2005 09:28:51
NAPA has a regular 12 V coil and the part number IC14-SB ($13.99) that will work in your 12V system. You might have had a 6 volt coil without a ballast resistor in the primary circuit that probably caused the overheat and failure of the coil and burned the primary wire. Make sure you don't have any shorts in that part of the primary circuit.
mgross
06-03-2005 07:06:10
 Re: New TO-20 in reply to Jerry/MT, 06-02-2005 18:13:21
Jerry,
Thank you very much for the suggestion. I'd picked up a 12v coil that had run over $30, since I haven't installed it yet I'll look for the one you suggested at NAPA. Is that what the resistor (internal vs external) is all about? To prevent cooking the coil when the ignition is left on?
Jerry/MT
06-03-2005 15:05:43
 Re: New TO-20 in reply to mgross, 06-03-2005 07:06:10
It's primary purpose is to limit the current through the coil all the time the engine is running to prevent coil failure via overheating. Only if your points are closed with the key is left on will there be a problem and there will likely be a problem with a 12 v coil also. It'll just take a while longer to fry a coil with an internal resistor. So turn that key OFF!
t020424
05-31-2005 13:41:08
Any good 12v coil, internally resisted, will work,that is if you dont have a resistor wired in. Battery boxes seem to be not that easy. Mine is plywood held up by 2 2x4s secured with...you guessed it, a bunjie cord. Good luck, have fun!!! Mike
mgross
05-31-2005 13:58:17
 Re: New TO-20 in reply to t020424, 05-31-2005 13:41:08
I assume if there is not a visible resister, I should go with an internally resisted coil. I picked one up but when I took it out of the box it said "must be used with external resistor"
and I've already cut a sheet of plywood, 2x4 too thick for this battery, wouldn't be able to close the lid... now, for a longer bunjie cord!
mark
