hydraulic fluid leaking
Grass Roots Far
05-27-2005 17:18:10
Wondering if anyone has an idea how to stop this fluid leak. The fluid seeps slowly but steadily from the connection of the body of the TO-20 tractor to the engine block, right next to where the oil pan is bolted. I have tightened all bolts in the vicinity, which has slowed the leak. Over 50 hours of use, I probably have lost 1 gallon of fluid. My manual gives me no help about gaskets and I don't know enough to know how these two sections connect. It sounds like a huge job to reseal. Any suggestions or thoughts might be helpful. Thanks in advance.
John(UK)
05-28-2005 08:10:25
 Re: hydraulic fluid leaking in reply to Grass Roots Farmer, 05-27-2005 17:18:10
Is the oil black (engine oil) or dirty green/brown (hydraulic/transmission) if it is hydraulic oil, then it is as Ray says, if it is engine oil, most likely it is the Rear Main Oil seal on the crankshaft. To repair this you will need to take the engine out of the tractor and also remove the oil pan. Mark the position of the flywheel as it comes off as it can go back in a different position and then the timing marks will be wrong.
Jerry/MT
05-28-2005 21:23:03
 Re: hydraulic fluid leaking in reply to John(UK), 05-28-2005 08:10:25
John, you don't have to worry about marking the flywheel. One of the studs on the crankshaft is offset so it can only go on one way. You need to mark that one otherwise it's the dickens trying to put the flywheel back on again!
John(UK)
05-29-2005 03:58:57
 Re: hydraulic fluid leaking in reply to Jerry/MT, 05-28-2005 21:23:03
Hi Jerry, you are correct, I was thinking about some of the TEA types that you have to do that, it"s the brain you know, not as quick as it once was, it"s getting like an old computer that is badly in need of either replacing or updating. Have a good weekend.
Jerry/MT
05-30-2005 19:00:07
 Re: hydraulic fluid leaking in reply to John(UK), 05-29-2005 03:58:57
Nothing wrong with your brain, John. You are the keeper of a bunch of Ferguson Facts. Cheers.
Ray,IN
05-27-2005 22:40:00
I assume you are talking about the hyd oil leaking from the small hole in the bottom of the clutch(rounded) housing. There is/should be, a cotter pin protruding from the hole. This cotter pin is loose and jiggles to keep the hole open. This drains hyd oil that leaks past the shaft seals in the front of the transmission. Otherwise the oil will contaminate the clutch itself. If the leak stops or really slows when the hyd oil level gets low, the above applies. It is a time consuming task to replace the seals, but is not really difficult if you have the shop manual. It will not harm anything to run the hyd oil level at the low mark on the dipstick unless operating remote hydraulic equipment, so if this is where the leak diminishes you might choose to tolerate the condition. With the proper equipment, parts, shop manual, and tools, 2 guys can replace the seals in 1 day. You can also just phone the nearest Massey-Ferguson dealer and ask for an estimate.
