fired her up!
Jake H
05-24-2005 18:37:48
hey everybody on this here discussion forum.... i finally went out and got enoungh stuff put back on my ole "55 TO-35 and fired her up this afternoon. i got the timin set right, filled it up with water, wired it up, then punched the starter button..... and after a few "put puts" she fired right up just like new. I"m going to show my grandaddy, who so generously gave it to me, this weekend what i have finally done after all these long months.
Jake H
Jake H
05-25-2005 12:35:56
 Re: fired her up! in reply to Jake H, 05-24-2005 18:37:48
i am sad to say that while doing my warm-up check...i have an oil and water leak. the oil is coming out of the oil filter housing and the water is coming from the gooseneck where the top radiator hose connects but that is from the sender for the temp gauge because the nut does not fit snugly around the sender. so what do i do...any suggestions, comments, person experiences? all are welcome
Thanks
Jake H
gshadel
05-26-2005 09:42:49
 Re: fired her up! in reply to Jake H, 05-25-2005 12:35:56
Jake,
if you have a standard capillary bulb type temp. guage, that nut holding the bulb down in the threaded port is not the actual sealing surface. The actual seal is between the flat machined face at the bottom of that threaded port, and that flared ring going around the sensor bulb that goes down in the port. The threaded nut makes those two surfaces seal when you torque it down on top of the bulb.
If your temp. port is like mine, that flat face at the bottom may not be flat anymore, full of rust, etc. I had to carefully grind it flat with a Dremel. If you are re-using that temp. sensor bulb, check that flared ring to make sure it is good, not mis-shapen. For extra insurance, add a dab of silicone gasket maker to the mating faces on the bulb and bottom of the port... not to the threaded nut or in the threads. That should get it.
gshadel
05-25-2005 07:36:43
Good Work !
It sure is a good feeling when an engine roars to life after you have tore it down and put it back together!
It is almost as satisfying when you put that tractor to work and feel the power of that engine pull thru a load
