Position Control
Iain Gibson
05-24-2005 14:27:23
I have built the poisition control device and am very happy with the operation. I do not understand the tapered or angle sde of the 3x2 box section. The direction the angle is when installed on mine is the equivalent of vertical towards the front of the tractor (if it was cut at 90 degrees instead of an angle. (Lift arms lowered) It almost interferes with the shaft on which the hydraulic control lever moves. From viewing pictures of one installed it appears as though the mounting bolts on my tract are 90 degrees out from those in the picture hence making the box section in the wrong position when mounted.
Can anyone help.
Thanks in advance.
Jeff-oh
05-25-2005 05:34:28
 Re: Position Control in reply to Iain Gibson, 05-24-2005 14:27:23
The angle part is not essential to the design. It"s purpose is to provide a reaction surface for the position stop if used. (that is the wing nut piece you asked about earlier).
I think the normal direction of the two bolts at the end of the lift arms is horizontal.
Jeff
