to-20 manifold
gastonr
05-19-2005 04:50:08
Any tips on removing and installing a new manifold would be great. For example should I remove the gas tank? Does anyone know the torque specs for the bolts, etc? I need to get that manifold on soon as I am rapidly loosing the ability to hear without a muffler!! I"ll keep ya"ll posted.
gshadel
05-19-2005 18:04:03
 Re: to-20 manifold in reply to gastonr, 05-19-2005 04:50:08
My service manual lacks any info on manifold torque. When I changed mine a couple years ago, I just torqued to standard grade 3 spec's. For a 9/16 nut that would be 70-80 ft pounds. Use a new gasket and tighten in some logical sequence to avoid stressing one side or the other and to get even torque on all nuts.
You will find that some of those nuts are really hard to get a socket on them due to close clearance of the manifold. I had to use an open end wrench on a few of them. It takes about 10 minutes to pull the tank, and worth every minute to help you get easier access to the manifold.
Run your engine for a while, let cool and retorque. The nuts I removed with my old manifold were super rusty and worn. I spent a couple bucks on new fasteners, made the install go easier.
Good luck
Frank (VA)
05-23-2005 19:33:13
 Re: to-20 manifold in reply to gshadel, 05-19-2005 18:04:03
After you torque the bolts down run the tractor for a while. Then when it heats up retorque the bolts. You may have to do this two or three times.
Frank
gastonr
05-19-2005 19:15:52
Thanks for the reply. What method did you use to remove the old gasket and clean the block before installing the new manifold?
gshadel
05-21-2005 06:03:40
 Re: to-20 manifold in reply to gastonr, 05-19-2005 19:15:52
Scraper should get it pretty good. I think I used some steel wool to shine-up the block surface under the old gasket. Didn't use any sealer on the new gasket.
I painted the new manifold with Hi-Temp paint before installing.
