to-20 oil
jbm
05-18-2005 10:52:47
have the motor parts back and am starting to re-assemble, what grade oil should I use? Can I use multi-grade or synthetic? Also what rear end/hyd oil should be used? Hope to try and fire up this weekend, been nearly 15 years since Grandpa used it last. Thanks for the replies.
gerard
05-19-2005 14:05:17
 Re: to-20 oil in reply to jbm, 05-18-2005 10:52:47
With respect to other posts on this subject, I"d never recommend a high detergent oil (eg oil designed for diesels) in an engine that doesn"t have modern filtration.
The detergent is designed to remove soot and other contaminants & keep them in suspension until the filter takes them out. Early filtration systems (especially by-pass ones such as on TE"s, will not clean properly - result - the oil becomes a grinding paste going round the engine. I"ve actually seen an engine wrecked in under an hour by using HD multigrade. It cleaned everything up so much that the engine started consuming oil rapidly - so much so that within an hour it had seized up beyond repair as it ran out of oil.
Use a multigrade in the engine by all means - given the wider clearances in old engines I"d suggest 20/50 as best, but beware those with high detergent factors.
gshadel
05-19-2005 09:27:06
 IRe: to-20 oil in reply to jbm, 05-18-2005 10:52:47
I don't think there was multigrade oil back when the original oil spec was established. Since your re-doing the engine, I see no reason to not use a multigrade oil. I use 20W-50 diesel grade in my TO-20 since I buy that stuff by the case for my trucks already. My pressure guage is always max'ed out ~25-30 PSI. Maybe I should switch to 10W-30/40?
I buy 1 quart of 30 WT oil for the air filter.. that last me a couple years. I don't know how the air filter will work with a 10W grade... probably just fine.
General consensus on the tranny oil is to definitely stick with the GL-1 mineral oil, not that thin "general purpose" hydraulic oil and not multiweight gear oil.
Chopper2
05-19-2005 04:58:29
If you want to find all the gaskets you have not touched durring your overhall, use multi grade detergent engine oil. The gaskets will all start to leak oil in your next 50 hours of operating time. I strongly recommend you use the oil as stated in your operating manual, 30 grade for summer (above 40F), 20 grade for winter. Valvoline still make it, but you may not find it on the shelf.
Good Luck
Jerry/MT
05-19-2005 11:20:46
 Re: to-20 oil in reply to Chopper2, 05-19-2005 04:58:29
Respectfully, I used (and continue to use) 10W40 multivis oil in my newly rebuilt engine and have no such problem.
Glenn/Calif
05-18-2005 19:39:26
Over the last 60 years I've found that motor oil is motor oil if changed regularly. The new multi-grades (10-30 or 10-40) seem to work very well. The synthetics are a lot of hype in my opinion (That and a buck might get you a cup of coffee). One of the guys mentioned break-in and I agree it is very important. But, the Trans/Axle/lift is another ball of wax. I found that NAPA Auto Parts is the best price and service. They don't carry it in all stores, but will order it and have it within 48 hours (24 hours most of the time). The NAPA P/N is 65-205 and it's GL-1 certified. Price last November in Calif was $24.99 per 5 Gal bucket, plus tax if applicable. One of the guys in Ohio said he paid $26.00 so figure from there. Good luck with your rebuild and restoration.
LOL Glenn
Gerald J.
05-18-2005 19:33:03
Apply some stiff oil or thin grease to all the bearings as you assemble. I've used moly grease with good results.
Then use a good quality oil with corrosion inhibitors and detergent to keep the engine from eating the bearings and to keep it clean.
Gerald J.
Zippy4554
05-18-2005 18:08:01
 new engine and old engine recommendation in reply to jbm, 05-18-2005 10:52:47
For newly rebuilt engine, I would not use a synthetic. They are just too good and it will take a very long time for the rings to seat right. I would just use a petroleum oil for quite awhile. I don't know if switching to synthetic would be ok after that, I had some old motorcycles that leaked (more than usual) when I used Mobil 1.
For my very tired old TO-20 that burned oil and fouled plugs, I tried these newer oila designed for "old" or worn engines. They are readily available, usually says something like "good for engines with over 75,000 miles...etc). Anyway I think this is working better for me. I keep track of the hours before I have to clean the plugs and it is definitely lasting longer.
gastonr
05-18-2005 17:27:19
I use hd-30 for engine and mineral oil for the trans./hyd. I live in SC and hd-30 castrol seems to work fine. I also use it in the oil bath filter.
Jerry/MT
05-18-2005 14:47:14
You'll hear a lot of different opinions about this subject but multi-vis oils(10W30 and 10W40) with the latest API service classification are much better than what originally went into these tractors when they were new. Some folks even use 15W40 for diesel service in them and if I lived in a warmer climate I probably would. Don't forget to service the oil bath air cleaner while you're at it. It's often overlooked.
Regarding the transhydraulic oil, get what ever meets the Massey Ferguson spec. I believe that it's GL 1 80W for summer or 90W for winter. Other transhydraulic fluids may be acceptable. DO NOT USE A REAR AXLE FLUID! You need to use a fluid specically made for transmission ands hydraulic use. By the way, do you have an owners manual or a shop manual? All this info is contained in thereHope this helps.
