to-20 carb
gastonr
05-16-2005 04:21:45
TO-20 running rough. Installed new points and plugs. Making a popping sound/skipping from exhaust. Distributor is worn may need to replace, but I saw another post referencing a clogged inlet screen in carb. Where is this screen located? I'm kinda worried about taking the carb apart for fear of messing it up with trash or messing up the gasket. Is it pretty easy to get to without takeing too many parts out of the carb?
Fred OH
05-19-2005 07:08:00
 Re: to-20 carb in reply to gastonr, 05-16-2005 04:21:45
Shut off gas at the shutoff on the settlement bulb assy. Disconnect the gas line at the brass elbow on carburator. Take a container and hold under the end of the gas line and turn the gas back on....it should come out of the line about like a man peeing...if it doesn"t, clean the filter in the upper part of the settlement bulb....also check inside of tank...sometimes crud will get around the little standpipe there. If it is running fuel as it should, take out the little brass elbow where the gas line connects to the carb and clean out the screen on the frontend of it....use an air hose for that. Sometimes this elbow is hard to stop from leaking when you put it back together...you might have to get a new one...two or three bucks from a Ford dealer...they use the same thing....Be careful not to cross thread it. If after putting it back together and with the high speed metering jet adjusted right...( I adjust mine so that the engine will jump from idle to wide open throttle without hesitating)...it will not perform as it should...you might want to readjust the setting of the float level. I might as well tell you how to clean the standpipe inside of the tank too. While you got the gas line off, take the gas cap off and stick a rag loosly in the opening and turn the gas shut off back on and blow through the gas line with an air hose and then LOOK in the tank for crud...you may have to take the tank off if it"s bad. Now, you know everything I know about getting the fuel system going. Cheers, Fred OH
Jerry/MT
05-16-2005 18:24:03
The Marvel-Schebler carb is about as simple a carb as you'll find. The screen you're looking for is in the fuel inlet elbow. If it's clear there's another filter above the sediment bowl. If your distributor shaft/bushing is worn you'll need to rebuild your distributor or replace it.www.philbingroup.com in Portland, OR rebuilds 'em for about $100 plus shipping. Mine was worn and my TO-30 ran like a three legged dog. I had it rebuilt and it runs like a top.
gastonr
05-17-2005 17:53:41
 Re: to-20 carb in reply to Jerry/MT, 05-16-2005 18:24:03
Thanks for the info. I am going to check those screens carefully this weekend when I go out to my land. I am probably going to replace the distributor and possibly install electric ignition. If it isn't the problem this time, it most likely give me trouble in the near future. Thanks again for the advice.
tennessee farmer
05-16-2005 09:45:50
Might want to check your plug wires. Best way is to fire it up after dark and see if you see any arching.
gastonr
05-16-2005 14:47:12
 Re: to-20 carb in reply to tennessee farmer, 05-16-2005 09:45:50
I bought a tune up kit and changed the plugs, points, condesor, and rotor button. After I started the engine it was running about the same. I lowered the disc harrow and after a couple of hundred feet it started pup-pup-puping again under load, like it isn't getting enough gas or something is still wrong with the electrical system. The wires are only about 4 yrs old but a set came with the kit as well as a distributor cap that I haven't put on yet. I am going to go ahead and replace them this weekend. Thanks for the advice.
John(UK)
05-16-2005 08:21:57
The screen or filter you ask about is in the elbow on the fuel pipe into the carburettor. No need to take the carb apart or even take it off the tractor to do this. If you can visibly see the shaft open and close the points if you rock it by hand then it does need replacing or repairing, just think of what it will be doing when the engine is running hard. Have you checked valve clearances too.
gastonr
05-16-2005 14:39:54
 Re: to-20 carb in reply to John(UK), 05-16-2005 08:21:57
The distributor seems to have a lot of play in it. The rotor button fits loose ( I don't know how else to describe it). I haven't checked the valve clearances because I'm not sure how to go about it. Hopefully it's a fuel problem. I appreciate any advice.
John(UK)
05-17-2005 06:05:41
 Re: to-20 carb in reply to gastonr, 05-16-2005 14:39:54
If the button is loose it shouldn't be a problem unless you can move it back and forward in the direction it rotates, then it could interfere with the timing. If the shaft is loose in the Distributor (you can move it side to side) it will alter the points setting as it runs and that could cause you problems such as you are getting now. If this is the case then the distributor needs repairing or replacing. If you need more help, then email me at :-
fergusontractors at tiscali dot co dot uk
telling me what your problem is.
gastonr
05-17-2005 17:56:32
 Re: to-20 carb in reply to John(UK), 05-17-2005 06:05:41
Thanks for the info. I may need you advice in the near future and am greatful for your help.
