timing
Jake H
05-14-2005 16:39:54
when i set the timing on my motor(Continental Z134) should the #1 cylinder rocker arms be loose or should they be tight...i realize that if i do it backwards i will be 180 degrees out of time and i dont want that!
thanks yall
Jake H
John(UK)
05-16-2005 07:45:09
 Re: timing in reply to Jake H, 05-14-2005 16:39:54
Both valves on No.1 cylinder should be slack. This shows that that cylinder is on compression stroke.
Tom H.
05-14-2005 17:56:09
I just went through all of this with getting my TO 30 Z129 going. The Rockers should be loose, hence, on compression. While the cover is open you might as well check the rocker arm gaps to make sure they are not to tight or sloppy.
Good Luck.
