new toys for my TO20!
gshadel
05-13-2005 13:12:11
I had a question here a while back asking if a TO-20 could pull a subsoiler okay.
Well, I bought one, and also stumbled across a bargain on a post hole digger.
My TO-20 ripped that subsoiler right thru the ground, buried all the way down (~12"),all afternoon, in 1st gear. I also easily ripped out some good sized tree roots, an several 2-3" stumps. I can already tell my pasture drains better since ripping it with the subsoiler. I like it!
I used my P.H.Digger to dig holes for 25 berry bushes, a dozen peach trees and rose bushes, and 25 grape vines.... in one evening, never broke a sweat. I did the same planting last year by hand, took all day, and I was sore for days. Ran the engine @ 850 RPMs while digging holes, worked GREAT! I was worried about not having live PTO for the P.H.Digger but found it wasn't a problem at all.
Even impressed the wife (rose bushes). Helped justify the time and money I spend "working on that old tractor".
It's hard to beat a good tractor with a few nice toys... aint it?
steve_ne
05-18-2005 06:10:27
 Re: new toys for my TO20! in reply to gshadel, 05-13-2005 13:12:11
This is somewhat late in posting this thread. But do you use a orc on the post hole digger. If you end up hitting something big that going to hurt?
Paul F B
05-14-2005 08:57:25
Does the to 20 come stock with a tacometer?
gshadel
05-16-2005 07:14:32
 Re: new toys for my TO20! in reply to Paul F B, 05-14-2005 08:57:25
I have one of those Northern Tools tach's that George mentions. Had it for ~1 1/2 years now. It works great for what I need it for.
George in NW Mich
05-14-2005 18:21:55
 tachometers and TO-20s in reply to Paul F B, 05-14-2005 08:57:25
The TO-20 did not come with a tachometer.
If you have converted to 12 neg ground, then you can buy a tachometer anywhere. You should however look for a small one with a 270 dial and a low rpm range. You won't find those so easily but they are available. Check the big instrument makers....especially Datcon in PA.
If you have 6 volt pos ground (the way it came), then the options are not as good. You can get one for about $50 from Northern Equipment that operates on its own battery...so it does not care about your battery or polarity. These also have a built in hour meter. I have one and it is ok....but it only updates the rpm every few seconds. So it does not track or respond the rpm very quickly. This is sort of ok for a tractor usually running at a constant speed. It has a digital readout, not a dial.
You can also get 6 volt pos ground tachs from Westech, not listed in their catalog, but they will supply them. They cost more, not sure of exact price, but they are a much more satisfactory instrument. Check their website.
Paul in Ms
05-14-2005 05:31:40
Life is good with new toys. Paul
