phil(va)
05-09-2005 16:37:13
Re: Newbe questions in reply to Tymoc, 05-09-2005 10:28:39
You didn't say what Ferguson you are looking at. I going to assume it is either a TO30 or a TO20. If not, ignore much of my answer. The Ferguson has draft control, but a better question for a previous 8N owner would be, does it have position control. The answer to that question is 'NO' it does not. You will need to add position control if you do bush hogging or if you scrape a driveway with a blade, etc. Zane Sherman in Alabama, and on the 8N board, sells the Zane Thang which will add position control to a Fergie (or 9N) and I believe his current price is $90 delivered. As for things to watch for, make sure it does not have any cracks in the block, or if so if they have been properly repaired. Check the oil for coolant and the coolant for oil. Brakes are similar to car drums and adjust same as old cars, just not hydraulic of course. TO30s and 20s have one main brake pedal for both brakes, and right and left pedal separate levers are back near thigh, not side by side for your right foot like 8N. Some like that, but I prefer the 8N arrangement myself. A TO30 will outpull a 8N, mostly due to the overhead valves I suspect. It will pull more like a NAA. The TO20 has the oil filter in the pan, which is a pain, and of course the 20 has less power than the 30. I wouldn't go back to a 20 if I had been using a 8N, and I'm mostly a Ferguson guy. As the other post said, if you want to step up, look for a TO35 (or Ford NAA). Hope that helps.
