clutch alignment
johesmi
05-07-2005 15:24:14
Hoping some one can give me some advise on installing a clutch on a Ferguson TE 20, my problem is,I removed the clutch to install a new oil seal,now my problem is how to install the clutch plate with out a pilot or some type of guide,hope some one has a short cut,or something ,I am bewildered.
johesmi
05-08-2005 09:11:41
 Re: clutch alignment in reply to johesmi, 05-07-2005 15:24:14
Just wanted to thank every one for there in put on reinstalling a clutch plate,sounds like a lot of great ideas ,should save me a lot of headaches,thanks again.
Paul in Ms
05-08-2005 05:35:06
I have always used a 3/8 or 7/16 1/2 drive socket. The big end was good fit in the shaft hole in the disk. The tapered end of the socket fit in the pilot shaft bearing in the crankshaft. I have used sockets and adapters on many clutch jobs. Works great.
Jerry/MT
05-07-2005 20:36:59
You can make a pilot out of a broomhandle if you're real patient or for under $10 you can by a set of clutch pilots at Harbor Freight Tools.
Little Dave
05-07-2005 20:07:24
It is a little more work but you can pull the front input shaft of the transmission and replace the seal and gasket and while you have it out use the shaft to install the clutch plate. Four bolts and it pulls out and you have to pull the brake cross shaft also . Dave
