conversion 6v to 12v
John1939
05-06-2005 05:39:58
I'm changing a TO30 to a 12volt system but need help on where to run the wires since I'm taking out the old voltage regulator.
John(UK)
05-09-2005 09:12:51
 Re: conversion 6v to 12v in reply to John1939, 05-06-2005 05:39:58
I have a wiring diagram for a TO30 with an alternator conversion, do you need single wire or two wire though. If you need it email me at fergusontractors at tiscali dot co dot uk
and tell me exactly what you need.
nonac99
05-06-2005 20:05:02
Check out the information at this web sight Link
Many>Link thanks to John Billingsley and all others who post useful information on the internet for all to use.
nonac99
05-06-2005 19:46:06
Assuming you will have a negative ground:
On the alternator you would run a 12 gauge wire from the BAT terminal to P2 terminal. From P2 to the plus terminal of the battery run a 10 gauge wire. From the P1 terminal of the alternator to the ignition switch run a 12 gauge wire. Cut this last wire in two and solder in a diode. Point the side of the diode with the white line at the P1 terminal of the alternator. use any diode that is 1 amp or higher and 50 volts or higher. This last wire should get 12 volts when the ignition switch is on only so make sure you connect it to the correct side of the ignition switch. If you don't have the plug for P1 and P2 just use ordinary female spade connectors.
nanac99
05-07-2005 10:18:15
 Re: conversion 6v to 12v in reply to nonac99, 05-06-2005 19:46:06
Thanks nanac99. That is the information I'm looking for so many thanks. John
Paul in AZ
05-06-2005 08:18:52
Go to the following site and you will find a wiring diagaram for a 12V TO-30.
John1939
05-06-2005 17:41:31
 Re: conversion 6v to 12v in reply to Paul in AZ, 05-06-2005 08:18:52
Thanks Paul for the info. The problem is that all of those diagrams were with the generator and regulator. I replaced the generator with an alternator with built in regulator. Maybe I can take a diagram and figure it all out, just hoping that someone had already did it. Thanks again.
