steering box lube
hank n' tx
05-04-2005 20:25:25
what kind of lube should i use in my to 30 steering housing? thanks hank
gshadel
05-05-2005 12:42:00
 Re: steering box lube in reply to hank n' tx, 05-04-2005 20:25:25
Hank, I believe the manual says to use the same oil as you add to your tranny.... that means 90 wt GL-1 mineral oil. I doubt the type of oil for the stearing gearbox is as critical as your tranny/hydraulics though. My guess is any 80-90wt tranny oil would be fine. Lot of guys pack the gearbox full of grease rather than tearing into the gearbox to replace worn out seals, or have oil leaking out of it all the time. If that's your problem, I've seen posts from quite a few guys that used J.D. corn head grease, pump a couple tubes in there, and it should last forever.
