Now it just won't start
Tom H.
05-04-2005 05:24:17
Thanks for the help on setting the timing. It looks like whether you set it at 6 degrees with a spark or 32 degrees with the advance it is in the same place.
The problem I am getting now is no gas to the cylinders. The carb had been off for almost two months and sitting by itself in a box. Something may have gotten into an opening and is clogging it up. There is plenty of gas in the bowl, I pulled the bottom plug and gas ran fine. I will be pulling the carb off and giving it a cleaning and go from there.
Thanks for the help. This site is always great for troubleshooting and getting answers to questions.
Jerry/MT
05-04-2005 20:57:39
 Re: Now it just won't start in reply to Tom H., 05-04-2005 05:24:17
How do you set the timing statically with full advance? Seems like it'd take three hands. You'd have to torque the distributor shaft to extend the springs that are normally actuated by the flyweights centrifugal force. Seems like a lot of work when you can do it statically in a straight forward manner.
Did you check the shaft for radial play? A lot of these old distributors are really worn because most people don't fill the oil cup regularly. They need new shafts and bushings. You might want to check that also.
Regarding the carb, make sure that the joint where it is attached to the manifold has a good gasket and seals well or you'll have a real lean mixture and if you start, you'll run too hot. Also make sure that your float level is set correctly.
Good luck.
