TO-30 valve job
clearfield
04-21-2005 08:34:39
Hello group
I am doing a valve job on my TO-30 Continetal 4 cyl I removed the valves from the head and I do not see and stem seals are there none or am I missing them someplace
thanks clearfield
Little Dave
04-21-2005 16:54:41
 Re: TO-30 valve job in reply to clearfield, 04-21-2005 08:34:39
The valve stem seals are only on the intake valves in between the two metal cups.
gshadel
04-22-2005 10:55:28
 Re: TO-30 valve job in reply to Little Dave, 04-21-2005 16:54:41
Dave's right. Chances are your old ones are so mashed-down you might not even see them until you pry apart those caps. You get new o ring seals for the intake valves if you buy a rebuild gasket set.
John(UK)
04-21-2005 11:10:42
They don't fit them to that engine
