TO-20 starter work on a TE-20
greg scott
04-20-2005 12:30:09
having trouble finding drive gear and shaft for lucas starter on my dad"d te-20. a rebuilt delco starter for the to is cheaper than the te and was wondering if it will work
Delbert Carman
04-21-2005 10:54:15
 Re: TO-20 starter work on a TE-20 in reply to greg scott, 04-20-2005 12:30:09
I have a 48 TE-20 with the Continetal engine. Starter went bad first, couldn't find parts, (this was before I had a computer to shop with. Then the clutch went. I can't rember what it had but it was an english clutch. No parts were available for it at theat time either. An oldtimer told me to get the flywheel, clutch parts and starter out of a TO-20. They bolted right in, and I can get reasonably price parts from my MF dealer, and NAPA, and others. As I sometimes spray with a electric pump sprayer, I have put on an alternator and 12 volt battery. Hope this will help somebody keep their TE running.
John(UK)
04-21-2005 11:36:32
 Re: TO-20 starter work on a TE-20 in reply to Delbert Carman, 04-21-2005 10:54:15
Parts are available for TE20 series tractors from "Sparex" and "Vapormatic" you order these through your usual tractor dealer or on this site. If you have difficulty getting hold of spares for the TE series just ask, we should be able to find them or even if they are available.
fergusontractors at tiscali dot co dot uk
danct
04-20-2005 17:05:33
Greg
i was the one who posted awhile back about finding the company that John UK mentioned,i tried a TO starter on mine but it didnt work ,someone told me i would have to change the ring gear to get it to work,,anyway i found the part for the LUCAS starter from the name mentioned and was able to fix it myself ,cost was around $40.00 i think ,i think my starter #is 25519 if yours is the same give it a try
good luck Danny
greg scott
04-22-2005 06:07:43
 Re: TO-20 starter work on a TE-20 in reply to danct, 04-20-2005 17:05:33
i called marc one and they said they don't list any parts for that starter, but if i sent them the drive they could repair it.
danct
04-22-2005 07:01:13
 Re: TO-20 starter work on a TE-20 in reply to greg scott, 04-22-2005 06:07:43
greg
in the starter drive itself is a part that has a rubber type material in the interior,this rubber becomes unglued over the years and it slips when torque is applied to it,it is easy to miss and drove me crazy tiil i figured it out ,the same company has this part also and if you send them the whole starter you may save yourself some time,i didnt do it this way because being Irish means we have to do it the hard way ,one other thing ,if the battery mounting bolt on the starter is anyway worn have them replace at this time,i also did this myself and it is not fun
let us know how you do
Danny
greg scott
04-21-2005 06:38:48
danny
i have the same starter. i will call them today.
thanks to everyone for the information.
Greg
John(UK)
04-20-2005 14:17:18
Yes you can use the Delco starter on TE20 but you may have to shim the starter out from the cylinder block and flywheel so the pinion won't catch when not in use. Have you tried these people for the starter gear:-
The company can be looked up under www.marcsone.com ,they have offices in Arizona and California,i spoke to a man named Khoi Vu and he knew exactly what part i was talking about,his phone # is 877-627-2111
This is an extract of a previous posting on here.
Jeff-oh
04-20-2005 12:39:49
Value built lists a Lucus starter for ~$285 with exchange. FYI
greg scott
04-20-2005 12:47:23
 Re: TO-20 starter work on a TE-20 in reply to Jeff-oh, 04-20-2005 12:39:49
that's roughly the price i found, but the delco one for the TO is about a $100 less. that is why i am asking. thanks!
