T020 3 Point Won't Lift
Griz
04-19-2005 23:04:15
I tried to use the tractor today but the lift wouldn't rise. It was working normally when I parked the day before. My guess is a valve is stuck open. What must I do to get the thing going again?
Griz
04-20-2005 21:36:35
 Re: T020 3 Point Won't Lift in reply to Griz, 04-19-2005 23:04:15
Thanks for the come back. I removed the dipstick side cover and didn"t see anything disconnected. I wiggled the linkage around and it lifted. The linkage must have gone past the point of no return. It is just fine now.
John(UK)
04-21-2005 11:38:08
 Re: T020 3 Point Won't Lift in reply to Griz, 04-20-2005 21:36:35
What had happened is that the Control Valve had just stuck, this can happen if you get a bit of wear on it. If it gets too bad you can get new ones.
John(UK)
04-20-2005 10:05:38
No such thing as stuck open on this system, it will just be stuck. remove round side cover and move the long control fork hanging down back and forward if it will go. That should free is. If you still have trouble, email me at:-
fergusontractors at tiscali dot co dot uk and I will send information sheet on what to do next.
