oil routing in and out of filter....I don't unders
George in NW Mi
04-16-2005 19:20:12
While putting my rebuilt oil pump, I started to wonder about the plumbing. I see the pickup tube is outside the filter, but I don't see how the oil is supplied to the inside of the filter.
Shop manual says there holes in the standpipe that comes down the middle of the filter (the pipe that the cover bolt goes into).
But I don't see any holes in this pipe, are they really small, or am I missing something here?
Duner Wi
04-17-2005 07:09:40
 Re: oil routing in and out of filter....I don't un in reply to George in NW Mich, 04-16-2005 19:20:12
The oil filter on Continental Z120 is fed off the center main and if you look close there is a small metering hole in the side of the pipe that goes down the center of the filter. This would lead me to believe not very much oil gets filtered on one pass thru the engine. I believe this to be correct.
George in NW MI
04-17-2005 08:04:19
 another question re the install of screen in reply to Duner Wi, 04-17-2005 07:09:40
Thanks for that information, I guess this is not a full flow system.
I took the screen out of the bottom and forgot to note which end is up. Does the open end point down so the filter and be easily pulled out, or does the closed end of the screen basket point down?
The shop manual is not clear on this.
gshadel
04-19-2005 10:04:12
 Re: another question re the install of screen in reply to George in NW MI, 04-17-2005 08:04:19
George, Screen goes in with the open end down. What the other guys said on that filter is right, it does not get full flow, just flow from the center bearing, the metering holes in the oil return are rather small. I question whether that filter really even does much good. The strainer is the most important part, it insures nothing gets sucked into your oil pump and causing damage.
When I first got my TO, the oil strainer was in upside down also, must be a common mistake.
There is also a small spring that is suppose to go on the oil return line..... I can't recall now if the spring goes between the crank bearing and the strainer, or between the strainer and the filter. Maybe one of the other guys knows for sure.
Duner Wi
04-18-2005 10:36:01
From a picture in the dealer shop manual the filter comes out first and then the screen assembly. Hope this helps.
Gerald J.
04-17-2005 08:48:06
It definitely is a bypass system, not a full flow filter system.
I think the screen goes down so it can inhale oil the longest when the oil is low.
Gerald J.
