going about grinding valves
hank n' tx
04-11-2005 17:16:59
just tore down a to 30. going to attempt to do a valve job. this will be my first. what tools and stuff do i need and can someone give me some simple step by step instructions of doing it. thanks hank
gshadel
04-12-2005 14:45:30
 Re: going about grinding valves in reply to hank n' tx, 04-11-2005 17:16:59
The simplist instructions I'd recommend is get a manual. It would take a dozen posts to get all the info that is in the manual. Might get lucky and find a manual at the public library.
The hardest part for me was getting the springs compressed and pulling the little keeper pins without shooting the thing apart under tension. The valve spring tools from the auto parts store didn't fit right, too wide.I found a cheap prybar at TSC, the end has an angle on it, that worked good for that job. Local machine shop charged me $70 to press in my new guides, grind the seats, check for warp, clean and paint, that was last year. Money well spent.
Lapping valves with the lapping paste is only for final polish, light work. If your valves have worn grooves, face damage, or bent stems, you will waste your time trying to fix them with the paste lapping stuff. I have lapped valves with the lapping paste before by inserting the valve in the head, stick the valve stem in a drill chuck, and spinning the valve at ~medium/slow speed for a couple minutes. Worked good for me. There are special fixtures/tools for grinding valves, A machine shop will probably be able to do it cheaper than buying that stuff. The manual says the "test" for an adequate valve job is to turn the finished head upside down, fill each cylinder cavity with gas. The valves should hold the gas for ~20 minutes or more.
Jim in OH
04-12-2005 09:35:45
If the valves, seats and bushings are basically in good shape and you are just trying to "lap them in" to assure a good seal.. then go ahead.. However, if you have any significant wear or leaking valves then I suggest taking it to a machine shop... been a while, but for about $100+ had 3 angle grind, new valves, new bushings (pressed in), checked spring rate and height, and assembly..... I have tried to do the hand grinding on burned valves, but all I did was ruin a seat and a valve...
wayne2
04-11-2005 21:03:51
Hank, A guy could, buy coarse and fine valve grinding compound, and rubber cup on stick, apply coarse under valve 3 places and start fire with stick(cup)rubbing hands togeather when shiny (sorta) on both valve and seat go to next valve and finish with fine compound. Where I'm from machine shop does it for 40 bucks. But there is value in a labor of LOVE>
Greasey Hand
06-03-2005 19:39:48
 Re: going about grinding valves in reply to wayne2, 04-11-2005 21:03:51
Sorry Boys You dont grind valves with the lap compound, Thats for checking them after thay have been groung on a valve grinder, The seats have to be ground on 3 diff angles, The valve eather 30 or 45 degree, The guides have to be checked also.
It sounds like there could be more money spent on these heads than need be, Ask some one who knows,
Seats & valves can cost a lot.
