TO20 lift top plate
Terry274
04-11-2005 15:10:22
I have a Ferguson TO20 and the lift has quit working on it. The problem seems to be in the linkage. I removed the pump and the control valve appears to be ok. With the pump removed I could operate the lift lever and the control fork would go back and forth, but when the fork is connected to the control valve it will not move the valve. I tried to remove the top plate to have a look at the top of the fork where it is moved by the lever but could not get the top plate off, is there anything that has to be done other than remove the bolts in the plate? Will the cylinder come out with the plate? Thanks for any help or advise, Terry
John(UK)
04-12-2005 05:29:47
 Re: TO20 lift top plate in reply to Terry274, 04-11-2005 15:10:22
Mail me at at:- fergusontractors at tiscali dot co dot uk and I will send you a fault finding sheet and other info. Tell me exactly what it is doing and I will tell you what to look for.
