Oil leak from gearbox main shaft, TEF20C -55
D. Lindholm, Fi
04-11-2005 08:17:33
Hi
I have a TEF20C -55 and the problem is oil on
the clutch plate.
I have located the leak, and the oil seems to
come from the gearbox main shaft.
-Can i renew the mainshaft oil sealing from
the clutchhousing, i dont have the time to strip down the whole gearbox.
-Can the flywheel sealing be renewed easily by
dismounting the flywheel?
Regards
D. Lindholm Finland, Europe
John(UK)
04-11-2005 13:50:58
 Re: Oil leak from gearbox main shaft, TEF20C -55 in reply to D. Lindholm, Finland, 04-11-2005 08:17:33
You can renew the Rear Main Crankshaft seal by removing the flywheel, yes. And you should be able to replace that seal too, you may have problems getting it off the bearing. If you need more information email me at:-
fergusontractors at tiscali dot co dot uk
Al in BC
04-11-2005 13:33:29
Input oil shaft seal is changed by splitting the tractor. Be Safe
When you are apart you will find that it had a very wide leather seal inserted. I believe it was 5/8" wide.(approx 15 mm.) When you are apart measure the shaft size and the seal seat size then go to your brg. and seal supplier and he will be able to supply. I changed mine and replaced this seal with 2 that sdded up to 15mm.. I was able to get 5/16 inch wide seals in to the space. I put one into retain the oil in the Transmission case and one in packed with grease for security. Both face the same way but the one with grease in is the one closest to the small end of the cone. SORRY FOR THE MIX OF MM AND SAE. NOT GOOD WITH MY METRIC.
If you have problems give me a note.
Al in BC
Al in BC
04-11-2005 13:36:26
 Re: Oil leak from gearbox main shaft, TEF20C -55 in reply to Al in BC, 04-11-2005 13:33:29
Hope John in the UK is allright with my fix. Some of us old Mechs have different ideas.
Al in BC
John(UK)
04-11-2005 13:53:13
 Re: Oil leak from gearbox main shaft, TEF20C -55 in reply to Al in BC, 04-11-2005 13:36:26
No Probs Al....seen it done before and it works fine.
04-20-2005 23:07:52
 Re: Oil leak from gearbox main shaft, TEF20C -55 in reply to John(UK), 04-11-2005 13:53:13
Thanks for the help.....
The tractor is now working as good as it should,
for the first time in my ownership, it is 19 years
older than me :-)
The parts that i renew :
-crankshaft rear oil seal
-the support bearing in the flywheel
-clutch plate
-the thrust bearing
-gearbox main shaft oil seal
-and a lot of work..... .done by myself alone :-)
Gearbox main shaft oil seal was the only part that I couldn't get, but a local seal wholesale found a new with the same dimensions, it was ~1mm thicker, but it fitted fine.
Regards
John(UK)
04-21-2005 04:16:26
 Re: Oil leak from gearbox main shaft, TEF20C -55 in reply to D. Lindholm, Finland , 04-20-2005 23:07:52
Glad you got the tractor repaired OK. If you need any more technical assistance please email me at:- fergusontractors at tiscali dot co dot uk
..... John
John(UK)
04-21-2005 14:20:32
 Re: Oil leak from gearbox main shaft, TEF20C -55 in reply to John(UK), 04-21-2005 04:16:26
That tractor is in very good condition and should be really nice when it is restored. Let me know if I can help any way.
Dennis Lindholm, Finland
04-21-2005 13:13:25
Hi, here is a link to a picture of my Fergie,
it is totally unrestored, not so bad shape for its age.
Link
Dennis Lindholm
