TO-20 Carb
MattinRaleigh
04-10-2005 13:02:34
Hello All,
I seem to be having a carb problem that came out of no where. Everything was working great until today. After about 15 minutes of use, tractor started running real rough and finally died. I checked the gas and was a little low so filled it up and tractor started right up, I made it 15 feet and it died again.
I drained carb, and then applied fuel, but I am only getting drops out after what is in the carb drains. I checked input to carb and had good flow ( I seem to rember a peeing reference some time ago, that is what I have here ).
Should I have the same full flow out of carb drain? Do you think I need to take it apart? Should I just by a new one?
Thanks to all.
John(UK)
04-10-2005 13:27:06
 Re: TO-20 Carb in reply to MattinRaleigh, 04-10-2005 13:02:34
Check the elbow into the carb, there is a filter inside. you have probably got all the crud from the bottom of the tank in there coz you ran low on fuel. You should get a good flow from carb drain, it won't be as fast as the main line into the carb.
MattinRaleigh
04-10-2005 18:03:30
 Re: TO-20 Carb in reply to John(UK), 04-10-2005 13:27:06
well, it was the filter you mentioned. Some carb cleaner and compressed air and I can see through it.
I am now running a little rough and have to adjust throttle occasionally, I suspect the carb needs adjusting since a good flow had been restored.
John(UK)
04-11-2005 09:17:20
 Re: TO-20 Carb in reply to MattinRaleigh, 04-10-2005 18:03:30
Hi Matt, Glad to hear you sorted it. If you need the information to reset your carburettor, mail me at:- fergusontractors at tiscali dot co dot uk
and I will send it to you.
