TE 20 timing
Lyle
05-02-2000 09:33:39
Can anyone tell me what the timing should be set on a TE20. I don't know if it is the same as a TO20. Thanks
Dusty Dave
05-03-2000 08:42:17
 Re: TE 20 timing in reply to Lyle, 05-02-2000 09:33:39
All I know about is the Standard motor--- which I think all TE-20s have.
There's a hole below the starter, in the forward-facing part of the block where the starter is mounted. It's a tiny little hole and hard to find under all the paint and dirt. There's a matching hole in the flywheel. The trick is to get them lined up. You can poke a small screwdriver in the first hole and get someone to slowly turn the engine over, though not by using the starter. Eventually, the flywheel hole will come around and the screwdriver will go through and then you can set your timing. You just have to be careful lest you catch the screwdriver in the flywheel and snap it in two! You can take the starter motor out to make it easier. What the timing actually is, I don't know, but I think it's TDC. Hope this helps.
Per Englund
05-04-2000 03:42:37
 Re: Re: TE 20 timing in reply to Dusty Dave, 05-03-2000 08:42:17
I have an 1948 TE-20 with an Continental and it is TDC.
Good luck!
Chuck (CA)
05-03-2000 16:18:44
I believe you're right about TDC.
Chuck
