Brake install
TB
04-06-2005 16:49:41
I'm trying to reassemble the brakes. I can't get the drums back over the shoes. Black spring on top shoe, blue on bottom, red at adjuster end.
Whats the secret? They'll only go on one way. They're not even new shoes. I'm at a loss other than getting out the sledge hammer. Any suggestions appreciated.
Tom b
tb
04-10-2005 05:40:25
 Re: Brake install in reply to TB, 04-06-2005 16:49:41
Thanks all for the replies. I was careful to keep the shoes,drums, springs etc. for each side together when I disassembled. The adjuster is compressed, there's no pressure on the rod to pull the shoes apart. I've got a manual and picture which is no help. Just can't get the drum over the shoe. Is there a difference between the primary and secondary shoes. They look the same to to me. Bout ready to push it in the ditch.
Tom B
danct
04-07-2005 06:50:16
TB
are the shoes in the correct position ,i think i installed the primary shoe in the wrong position one time ,or i installed two primary shoes on one side ,i know it was something stupid but i did it ,so go back to square one and use the manual
good luck
Danny
John(UK)
04-07-2005 04:53:03
Has someone played around with the length of the brake rods or are the independent brake pedals seized at the inner joint and not allowing the linkage to go to "off" fully. If you need an information sheet on how to set these brakes up email me at : - fergusontractors at tiscali dot co dot uk. and tell me again what the problem is so I dont have to look for this mail again.
Dale in WV
04-06-2005 17:03:08
You got that brake adjusting screw all the way compressed yet?
danct
04-07-2005 15:31:52
 Re: Brake install in reply to Dale in WV, 04-06-2005 17:03:08
Tom
you do have the parking brake clip released ,right?
TB
04-06-2005 19:59:51
yep, screwed all the way in.
Thanks anyway though
Tom b
Jim W
04-06-2005 21:04:13
 Re: Brake install in reply to TB, 04-06-2005 19:59:51
Is there a ridge around the inner edge of the drum maybe?
Jim
TB
04-11-2005 20:21:24
 Re: Brake install in reply to Jim W, 04-06-2005 21:04:13
It had a ridge but has been removed. Figured I wasn't out anything so I ground it off. Still no luck. Would seem to me it would just slip back on with no problems. Its a real puzzlement.
Thanks anyway.
Tom B.
