check of the gauge and lines, look ok
George in NW MI
04-06-2005 10:17:01
I took the oil pressure gauge off, it registers immediately when an air pump is conected to it.
I disconnected the line at the block and at the gauge and I can blow air through this line...not too fast however as the line is small.
I connected a rubber hose to the fitting on the block and I can blow air into the engine.
Looks to me like all this stuff is ok
Gerald J.
04-06-2005 10:57:53
 Re: check of the gauge and lines, look ok in reply to George in NW MI, 04-06-2005 10:17:01
May be time to pull the pump and see if the key is sheared on the shaft for the drive gear or an internal gear. Sudden loss sounds like a failure like that rather than wear from the pump. Unless the intake pipe has sprung a leak and pulls air easier than oil.
Gerald J.
George in NW MI
04-06-2005 12:51:18
 Gerald...a follow up question on shear pin in reply to Gerald J., 04-06-2005 10:57:53
Thanks again for your continuing help.
If the shear pin broke, would the outside big pump gear that you can see still turn when the motor turns over? I ask because this gear does turn when the motor does.
gerard
04-06-2005 15:24:49
 Re: Gerald...a follow up question on shear pin in reply to George in NW MI, 04-06-2005 12:51:18
Not unknown for outer gear to rotate whilst pump gears remain stationary. Pull the pump and look inside. Will probably need a kit to sort it.
good luck.
Gerald J.
04-06-2005 15:23:11
With pin or key sheared between the pump drive gear and the pump shaft, the gear turns but the shaft doesn't. When the shaft doesn't turn, the pump doesn't pump. This shouldn't happen unless there's metal been ingested into the pump.
Could even be a broken shaft inside the pump.
Gerald J.
