to20 add-on hyd
jbm
04-04-2005 13:52:18
have a 49 t020 I am restoring to use not show, was my Grandfather's tractor and he believed things should be used. Once I get done with the tractor I will be mounting the old ferguson loader for light use (snow mostly) but would like to modify to have live hyd. Can I replace the main pulley off the front of the engine and replace with a double pulley to drive an external pump? Any other ideas would be appreciated. Right now the tractor is torn down awaiting parts and paint so it will be a while for the loader, just planning. Thanks for any input.
gshadel
04-05-2005 05:38:46
 Re: to20 add-on hyd in reply to jbm, 04-04-2005 13:52:18
The pump mounted to the crank is a typical arrangement for a loader. You can install a belt driven pump the way you describe. Go to the 8N board on this web site and search for Zane's "Live Thang". He sells an add-on hydro- pump kit to outfit N's and Fergies into live hydraulics, run loaders, etc.
Tom H.
04-04-2005 19:01:29
I beleive you can mount a hydralic pump right to the crankshaft by replacing the handcrank nut with a coupling and the pump will mount in front of the grill. I have seen this done on Fords (they don't have hoods that tip to add gas) and also some Fergies that have had a hatch cut into the hood to get to the gas tank. Good luck
Tom H.
04-04-2005 19:07:14
 Re: to20 add-on hyd in reply to Tom H., 04-04-2005 19:01:29
One more thing. My dad had a 1940 Ford 9N that he added a loader to. To operate the hydralics (lift only) he and the Ford dealer built a bypass valve from the hydralic pump. When it was opened and the 3 pt hitch lift arms chained down the loader would operate using the regular lift lever. To use the back of the tractor again leave the loader up and shut off the bypass valve and unchain the lift arms.
We used this for quite a few years and only had to watch for the front to start drifting down over time.
This would save from butchering these irreplaceable hoods we have.
Tom
