flipped
thom grosse
04-03-2005 17:03:58
The Mrs. Boy decided he knew how to use my ferg.T20. he decided to ues the machine after I told him not to until I( had time to instruct him. He decided to pull a tree down going up hill.
He is 21. He was lucky he did not kill himself. He only flipped the nmachine, and cracked his hand an messed up his back a bit. Please let me know what type of gear lube to put back in, and where and type of hydraulic fluid.
I appreciate your help. I still got a lot of sheet metal to bend back into place thom
evetS
04-11-2005 10:43:46
 Re: flipped in reply to thom grosse, 04-03-2005 17:03:58
Besides the brush w/death from flipping over, what would happen if the chain were to break? How would the chain react? If there were pieces of it would he have been dodging bullets? Just courious. If I"m pulling something w/weight behind it I run my chain thru a length of pipe, in hopes it will stop the backlash if it breaks. Just my .02 worth, go ahead and keep the change!
Steve
TerryMi
04-04-2005 06:51:34
He is a lucky boy. Lucky but stupid. He did a double stupid, first by trying to pull a tree down, second by trying to do it going up hill. AS an earlier post said it is finally tractor season, lets all be safe, and think, so our wives dont't have to sell our tractors after the funeral.
Jeff-oh
04-04-2005 05:39:31
The the engine gets straight 30 wt.
The transmission gets 90 wt. GL-1 Gear Lube this is available at NAPA and is PN 65-205
Jeff
George in NW MI
04-05-2005 17:51:45
 flipping, why doesn't this happen in tractor pulls in reply to Jeff-oh, 04-04-2005 05:39:31
I have watched a number of antique tractor pulls. These tractors pull a sled until they cannot not pull it further and stop. They may lift the front wheels a foot or so, but they never go higher. Guys I have talked to said they had never seen one flip over. Isn't this just the same a trying to pull a tree down (except for the hill part!)?
It seems to me that the higher the wheels go, the less power it takes to make them go higher still. Once it gets to straight up, you could push it over with a finger. This principle is what makes motorcycle wheelstanding so difficult...it takes great still to keep the thing from flipping over like a shot. It is sort of a negative feedback loop, instead of self correcting it gets worse even faster.
What am I missing here?
Gerald J.
04-05-2005 19:41:11
 Re: flipping, why doesn't this happen in tractor p in reply to George in NW MI, 04-05-2005 17:51:45
You are missing where the chain was hitched to the tractor. A kid without thinking could handily hitch to the top link point of the three point or around the tractor axle. Either will guarantee a flip. Hitching to a drawbar on the lower link pins will do the same thing unless they are held down with stabilizer bars.
Then pulling a stump takes more tractor than the utility tractor so it gets tempting to back up and lunge at the end of the chain. Still won't move the stump but will lift the tractor front if the hitch isn't held low.
When trying to pull stumps the chain should really be hitched under the rear axle of the tractor up to the front axle, but only the front part of the AC snap coupler ever worked that way.
The kid was really lucky to have survived. Stump pulling kills lots of neophyte tractor drivers.
The drawbar on the pulling tractor is well below and behind the axle so that the lifting tendency of the front of the tractor pushes the hitch point even lower to help hold the front end of the tractor down. Tractor pulling rules generally demand the hitch be so placed to help minimize tractor flipping. And some rules require the driver reduce power if the front wheels won't stay close to the ground.
Gerald J.
Gerald J.
04-08-2005 08:22:00
 Re: flipping. And a lot of pulling tractors have w in reply to Gerald J., 04-05-2005 19:41:11
Wheely bars slow the flipping when they hit the ground behind the rear wheels.
Gerald J.
