Lucas Starter
Lyle
04-30-2000 20:11:48
On my TE 20, It has a Lucas starter with only one wire going to the starter. My question is what actually makes the starter drive gear push out to engage the flywheel. My starter turns but does not engage the flywheel. Any help would be appreciated.
Keith from Missouri
05-01-2000 08:15:23
 Re: Lucas Starter in reply to Lyle, 04-30-2000 20:11:48
I had this exact same thing happen to me about 2 weeks ago. I took the starter off and took it to an electrical rebuilder. I had just purchased this Lucas starter a few months back so I knew something was wrong. There is a pin in the gear that attaches it to the shaft. My pin had falled out, so all that was happening was the shaft was spinning and the gear would never engage the flywheel. Hope this is all the problem is.
rod
05-01-2000 03:54:02
When the starter spins it causes the drive gear to move out on the shaft and engage the flywheel if the starter spins it is ok the drive spring could be bad or your flywheel might have some teeth missing try turning over engine by hand if you have the crank just to move the flywheel a bit.
regards
rod
