Woods Mower
tractorfix
03-31-2005 14:45:57
I am interested in putting a L59 Woods belly mower under a TEA. My question is this. Do you require a tractor with POSITION CONTROL to operate these mowers? How is the mow height maintained?. Thanks !
Barry from Stirling
04-01-2005 09:31:10
 Re: Woods Mower in reply to tractorfix, 03-31-2005 14:45:57
Afternoon everyone
How does the mower get its power? Is it PTO driven, if so how is it rigged under the tractor? What is needed to do this. I own a 1952 TEA and would like to have the same set up.
Barry from Stirling
04-01-2005 09:29:39
Afternoon everyone
How does the mower get its power? What rigging is needed to do this. I own a 1952 TEA and would like to have the same set up.
Mike Groom
04-01-2005 07:59:38
I have a 6Ft. woods belly mower on my ford tractor,the depth is maintained by the wheels on the mower,it does a excellent job.Also,mine is for sale for $600.00
dhs
04-06-2005 17:35:03
 Re: Woods Mower in reply to Mike Groom, 04-01-2005 07:59:38
Where are you located?
marlowe
04-01-2005 07:49:58
your mower should ride on the ground on rollers or wheels when in use and NOT hang on the tractor so you do not need the position control. the mower must flow the roll of the land if it's hanging on the tractor you will get ueven cut and a lot of scalping
Jeff-oh
04-01-2005 07:37:07
I do not have a direct answer for you, however, a position control only affects the three point. If the mower is belly mounted, and not linked to the lift arms a position control will not affect performance.
Also, there are position control solutions other than Zane Sherman's. A position control can easily be constructed with basic building skill. The plans are presented in the Parts and Pieces Gallery.
Jeff
George in NW Mich
03-31-2005 20:09:14
 if you need position control get a Zane Thang in reply to tractorfix, 03-31-2005 14:45:57
These run about $80, a simple device that works perfectly to give position control on Fergusons. Takes about 10 minutes to install.
