Now I have doubts
mattinraleigh
03-28-2005 17:33:16
Hello all,
I thought I had a TO-20, I recently removed paint from serial number tag and revealed 79249. According to this site, that makes it a TO30, right? But I have doubts, the engine number has one number missing and I don't know if it is a Z120 or Z129. The 0 or 9 has been ground off. On the serial number tag, the only part that is legible is the SN, it is on the bottom of the tag, but I examples I have seen put the SN at the top of the plate.
I only have an oil pressure guage
I air cleaner does not go through dash
What else can I check?
phil(va)
04-01-2005 14:18:58
 Re: Now I have doubts in reply to mattinraleigh, 03-28-2005 17:33:16
Matt, I asked you in your first post on this subject if the oil filter was in the pan or external on the side of the engine, and you didn"t reply. A good start would be to tell us that. The TO-30 has the oil filter external, unlike the 20.
mattinraleigh
04-01-2005 14:23:07
 Re: Now I have doubts in reply to phil(va), 04-01-2005 14:18:58
Sorry, didn"t see your question, oil fileter is in pan.
phil(va)
04-01-2005 17:58:22
 Re: Now I have doubts in reply to mattinraleigh, 04-01-2005 14:23:07
Then it isn't a Z129, and therefore it isn't a TO-30 (or if it is, it has wrong engine). The Z120 on the TO-20 has filter in the pan.
mattinraleigh
03-30-2005 14:23:29
So it appears I may have a TE with possible bigger pistons. Acording to the dating near the rear axle by fluid check, it was made in 51.
I think I"ll call it a TE-29.5
I used it heavily today, no problems except the occasional root.
thank all
John (UK)
03-30-2005 11:26:28
If the the gearbox housing made of aluminium it is a TE series if it is a cast iron box it is a TO series. if its just got a big round plate on the oil pan its a Z120 - TO20 or TE20. If you have an external oil filter, if you have its a Z129 = TO30
MattinRaleigh
03-29-2005 15:58:46
So on the SN tag, is the SN at the top or bottom of plate. Maybe I have a fake SN tag?
Any idea why someone would take the time to grind off a number on the engine?
Jim in OH
03-29-2005 09:41:10
I am aware of five external physical differences between the 20 and the 30. Three have been mentioned (dash air inlet for the TO-30; external oil filter for the TO-30, Z120 marking vs Z129 marking on the engine for the TO-30). A fourth, I think, is in the casting for the rearend. In the picture, you can see a vertical hump or raised portion from top to bottom under the auxilary hydraulic tap on the right side. I am not sure, but I do not believe that the earlier tractors have this. A fifth is that earlier tractors (but not all of the later TO-20s) had the transmission cover as an integral part of the steering box casting (all one piece). ONly the later TO-20s but all of the TO-30s had the stamped steel cover.
Hope this helps. If you want a bigger picture, look at the same link but remove the "-small" from the picture name of the link
Jim in OH
Jeff-oh
03-29-2005 13:09:06
 Re: Now I have doubts in reply to Jim in OH, 03-29-2005 09:41:10
All TO-20"s have the seperate shift plate cover pointed out by Jim and shown in the picture. If the plate is integral with the steering column then it is a TE-20 from the Coventry, England plant.
Another possibility is that it a replacement Engine on a TO-30. In the past a Z120 could have been put on the TO-30 frame and the last number ground out to cover the fact.
Jeff
Jim in OH
03-29-2005 09:44:10
 Re: Picture!!! in reply to Jim in OH, 03-29-2005 09:41:10
For some reason, the picture did not work on the last post.....
Sam-Ga
03-29-2005 06:22:12
On my Z-120 the oil filter is in the oil pan,
