to 30 pto shaft stuck in frount assemby
mike in newyork
03-27-2005 16:10:44
has any one every had to deal with this? I think the shaft is slightly twisted .The tractor came to me this way so maybe it was abused . ive tried every way possibble to re move so Im think of cutting the shaft be hind hyd pump and spliting at the trans .after the frount pto assy is un bolted ,hopefully i can sneak the pto fr assy and pump back and down at the same time . well if any knows abetter way please come foward
Jerry/MT
03-27-2005 17:37:03
 Re: to 30 pto shaft stuck in frount assemby in reply to mike in newyork, 03-27-2005 16:10:44
Mike, Do a search in this forum. I've seen a lot of discussions on this issue. You'll have to cut the shaft aft of the pump but I don't think you'll have to split the transmission case. I've never done it before but I know several people have and they've detailed it in this forum. Good Luck.
danct
03-28-2005 07:08:21
 Re: to 30 pto shaft stuck in frount assemby in reply to Jerry/MT, 03-27-2005 17:37:03
look up Zane sherman over in the Ford 8n /9n section ,he has som good information on how to do it
good luck
mike in ny
03-28-2005 18:05:07
 Re: to 30 pto shaft stuck in frount assemby in reply to danct, 03-28-2005 07:08:21
thanks for the information .Im makeing some progress. the shaft is diffently twisted.thanks agian for the help
