TE20 Starting problems
Brian4501
03-26-2005 17:27:20
Was wondering if anyone could tell me on how to check the ing coil I think its bad but not to sure how to check tried using a volt meter like I would on a car or truck and to no sucess plugs were nasty and old installed new ones wires are very bad shape to I have not used them yet I was just tring to get it to show me some spark I cant get it any where out of coil or any of the plugs I really need to put a basic tune up on it any ideas on where to get cap and button ??
The story with this thing is TE54206 on plate 6 volt I dont know the year
My brother got it about a year ago work fine started ok he use it a few times parked it outside got cold out and snow had it coverd went to start it to move some snow would not start he said the batt was dead so he got a new batt and charged the old one nither one would get it to start and thats how it is now I'm not sure if I should do something different than I am on checking the coil scince its a pos ground I have never seen that before it cranks over like it should I suppose kinda slow I;m assuming cause its a 6v I someone could give me a few pointers or point me in the right dirrection on how to check for spark and where I might get the cap and button
Thanks
Chopper2
03-27-2005 05:36:39
 Re: TE20 Starting problems in reply to Brian4501, 03-26-2005 17:27:20
Brian; Check the battery ground strap, as per John"s instruction, and make sure your battery is installed with the POSITIVE post to GROUND!
John (UK)
03-27-2005 03:59:17
You should be able to get the parts from this site, top of the page look for H.Ferguson and click on it, follow it from there. It should be a 6volt at that number unless someone has converted it. If the ground lead is still attached to the back of the dash panel I suggest you make a new longer one and fasten it onto one of the starter bolts The contacts should be set to .012" and the plugs should be set to.030" Simplest way of checking the coil is remove the HT lead from the top of the distributor and hold it near the cylinder block, turn the engine over and you should get a bright blue spark if everything is OK. (hold the lead with insulated pliers) make sure the fuel hasn't gone sour, if it has it wont really smell like proper gasoline more like paint thinners, if is is like this, change it. You could change the condenser in the distributor, that could be faulty. You could also check the contacts in the starter switch on top of the clutch housing as they may be burnt or dirty. Check the starter to see if the brushes are worn or dirty.Moral of the story is don't leave it outside uncovered. You can email me at :- fergusontractors at tiscali dot co uk
if you need more help.
