T0-30 Head gasket
Ron
04-28-2000 19:57:22
Help I'm getting water into cyclinders 2 and 3. I have replaced and verified my torque and pattern. I have eyed the flattness of both head and block, with scale and feeler gages can't see anything wrong. Is there a different gasket or sealant I should/could use to insure gasket sealing? Let system sit over a couple of nights I get water in cyclinders. Am currently letting both head and block sit with water in them hoping to find something. Being a Electronics Tech, I thought I knew enough to get by. Is there a process that can be done on the head that may should cracks in exhaust or intake cavities?
ErnieD
04-30-2000 04:03:20
 Re: T0-30 Head gasket in reply to Ron, 04-28-2000 19:57:22
When you say you "eyed the head flatness with scale and feeler gauges", did you actually span the whole head with a straight edge? Get a straight, straight edge, framining square, whatever and span the whole head. The head will warp if overheated.
