Broken Power Lift Handle TO 20 1951
Bill H.
03-06-2005 13:38:05
I broke the power lift handle off at the position where the handle connects to the power lift shaft or rod. The base of the power lift handle that is broken appears to attach to the shaft or rod that goes below the seat on the right hand side. There is a keyed nut and spring that hold pressure on the broken base. The power lift handle was hard to pull up after being out of use this winter and I pulled it up and down several times and it finally broke off at the base. I suspect that I may have a greater problem than the lift handle, although the power lift raises and lower just fine with a wrench attached to the handle base. Two questions: Where can I order another handle? Are there any precautions in getting the broken lift base off the lift rod? Thanks Bill H.
John in WV
03-06-2005 16:18:43
 Re: Broken Power Lift Handle TO 20 1951 in reply to Bill H., 03-06-2005 13:38:05
Bill Call or Email me Can help you out 304 358 7271 eve.
Bill H.
03-07-2005 04:20:57
 Re: Broken Power Lift Handle TO 20 1951 in reply to John in WV, 03-06-2005 16:18:43
Will contact you as soon as I have time to get it off and have the part # etc. Thanks Bill
