51 TE-20 ferguson: Sleves vs. Liners
kitty
03-03-2005 12:09:10
I am having my 51 TE20 rebuilt. The first hurdle we need to jump is that all we can find are cylinder liners, not sleeves. The mechanic says the sleeves are square on the ends while the liners are round. Thanks for your response, Kitty
John (UK)
03-03-2005 12:32:12
 Re: 51 TE-20 ferguson: Sleves vs. Liners in reply to kitty, 03-03-2005 12:09:10
There are no 1951 TE20's they finished in 1948, if it's definitely 1951 its a TEA with a Standard Motors Engine. To check what engine you have, look for the oil filler it will be on the left side of the engine. If it is at the front it will be a Continental Z120 Engine, if it is towards the rear it is a Standard Motors Engine and could be 80mm bore or 85mm bore. The engine number for both is between the coil and the distributor which would be nice to have to sort it out.Very often the term sleeve is used for a cylinder liner too. No matter which engine you have they are available. You can email me direct at fergusontractors at tiscali dot co dot uk if you prefer
Jim W
03-03-2005 15:15:38
 Re: 51 TE-20 ferguson: Sleves vs. Liners in reply to John (UK), 03-03-2005 12:32:12
If it is a Standard Motors Company engine, i.e. if you really have a TEA20, you can use sleeves/liners from a Triumph engine of the same era. They are readily available from several sources for about $600 US including pistons and rings.
Jim W
J.J.DIESEL
01-02-2006 21:49:03
 cylinder liners sleeves in reply to Jim W, 03-03-2005 15:15:38
we are manufacturer of all cylinder liners & sleeves in india.we have an iso 9001-2000 comapany.please,visit our web site.www.jdliners.com
