TO-20
DAVE R
07-07-1999 14:59:21
I recently bought what I believe is a 1950 TO-20. The serial number is TO28598. I ordered a owners manual and the illustration for the air cleaner shows only one tube leading to the carbureter. On my tractor however, it also has a second tube leading to a glass container. Does anyone have a similar setup and if so can you tell me anything about this.
Thanks
Dave
Tex Ferguson
07-09-1999 16:31:16
 Re: TO-20 in reply to DAVE R, 07-07-1999 14:59:21
My '49 model TE20 has the glass dust collector jar as an attachment below the initial air intake tract(horizontal). The theory is that a spiral motion of the intake air stream spins the larger insects and dust particles out by centrifugal force, and they fall into the jar. A vertical tube then conducts the air up to the larger oil-bath air filter chamber. I haven't done anything with my dust collection in a couple of years, but it should be emptied if you notice uneven tire wear due to the unbalanced extra weight(ha-ha!).
Dennis F
07-08-1999 06:56:53
Can't think of any glass container on the tractor except for the glass sediment bowl that screws into the bottom of the gas tank with the fuel line to the carb coming from it.
