Response to John (UK)
Robert SHefferl
02-27-2005 14:38:28
Thank you for your response, I did what you said with no luck. The spark plugs were out of gap so I adjusted them. It is clearly oil that is coming out. I looked into the hole where the spark plug goes into and cylinder numbers 1, 2, and 3 all had a black wet appearance to them and #4 looked dry. Similarly the spark plugs for 1, 2, and 3 were all fouled up with oil and #4 was dry. The plugs appear to be relatively new. The fuel in the tank is all new. I checked the continuity of the spark plug wires and they all checked out. The cap and rotar also look relatively new and do not have any corrosion on them.
John (UK)
02-27-2005 15:03:07
 Re: Response to John (UK) in reply to Robert SHefferly III, 02-27-2005 14:38:28
Have you tried the compression on all cylinders, turning it over on the handle it should be springy when you do, if the compression is down on any cylinders it will need the valves grinding in. Turning it on the starter with fully charged battery you should get a pressure of about 100psi if you use a compression tester. Have you got the correct plugs for the engine, Champion L10 or NGK B6HS set to .030". Is the distributor cap cracked around the centre HT lead, is the rotor arm cracked. Is there wear in the distributor shaft allowing side movement to open and close the points gap as it runs. Any fuel in the bore will be unburnt and give the impression of oil but it isnt always. you could also check the valve clearances before you strip it down if any compresions are low. inlet .010" exhaust .012" all cold. Is the top of the coil cracked. is the condenser playing up, try another.Compression is main thing to get it going, if it isnt right then the head will have to come off and investigate further, it could be just valves you may have to check rings too. Try all this and then email me at:- fergusontractors at tiscali dot co dot uk
and we can go deeper into it.
Robert Shefferly III
02-28-2005 19:17:29
 Re: Response to John (UK) in reply to John (UK), 02-27-2005 15:03:07
John,
I sent you an e-mail as well, not sure if you received it. Here are the results of the compression check: #1 90, #2 65, #3 90, #4 90. I am in the process of locating the other parts at a place that has them in stock. Thank you for your help.
