TO-35 clutch
Tig Welder
02-26-2005 16:38:10
Ok how do i get the the second clutch out of the Spicer pressure plate assembly,on a TO-35.The throw out bearing failed and while I have this thing split I'm going to replace both clutch disc,so what's the trick????
John (UK)
02-27-2005 10:52:17
 Re: TO-35 clutch in reply to Tig Welder, 02-26-2005 16:38:10
You have to clamp the whole thing up as if it were mounted on the flywheel and the remove the setscrews that hold it all together SLOWLY then you can take it out. Its difficult to reassemble tho without the right kit and some knowledge.
