RandyR
02-27-2005 01:27:10
Re: Bad Running in reply to Jerry/MT, 02-26-2005 19:50:00
Concerning the coil, of the ones I've looked up on the net, some have about 1.5 ohms and some are 3.5 ohms, all 12 volt. How is someone supposed to know which to buy? I'm thinking a ballast resistor, or thermistor is the proper word, would be used with a 1.5 ohm coil, and the 3.5 ohm coil wouldn't need a thermistor. Am I right? The wires are set right for the firing order. Got 13.5 volts to the coil teminal. Pulled the lead off a misfiring plug and put a jumper on it and held it about 1/4 inch from the plug and got a good blue-snot spark. And the engine ran smoother. Changed plugs since then and it helped for a while. When I checked the timing with a light, it was erratic, so I pulled the cap again and found one spot where the shaft is a little loose, but nowhere else in it's rotation. Wierd. But it did affect the points opening. Also noticed the glass fuel bowl on the tank outlet is discolored and there is a layer of gray in the bottom. I'll pull it and check the screen. Unfortunately our local auto electric and ignition expert shop don't rebuild distributors, if it needs a new bushing, just starters, alternators, and gennies. Did a compression test almost 2 years ago and it was good, 145 on 2 cyl, 140, and 135 on the rest. The 135 came up to 140 with a bit of oil shot in the cylinder.
