TEA.24 Head problem
Reg Cornelius
02-20-2005 21:36:08
My 1950 TEA 24 developed water in the oil, on investegation found water squirting out of a 25mm dia plate between the two center head studs on the head.This plate similar to a frost plug had corroded.It apears to be made of aluminim I want to know what it is for and what it is made of.
Can i replace it with the head in place.
Can i repair it with some kind of filler
John (UK)
02-21-2005 15:52:14
 Re: TEA.24 Head problem in reply to Reg Cornelius, 02-20-2005 21:36:08
it is a plug to block the hole when they made the casting and you can block it with anything you can find, it will be OK. Most unusual to have that corrode like that but at 50 years old I suppose we can forgive it. It was made of an alloy like you thought.
Reg Cornelius
02-23-2005 21:52:04
 Re: TEA.24 Head problem in reply to John (UK), 02-21-2005 15:52:14
Thanks for the info.the old one turned out to be threaded into the head,replaced it with a 24mm frost plug.
John (UK)
02-24-2005 05:44:45
 Re: TEA.24 Head problem in reply to Reg Cornelius, 02-23-2005 21:52:04
Sorry I forgot to mention it was screwed in. As long as its ok now.
