Just got the TO 30 home with the Howard in it
Willy-N
02-20-2005 17:56:07
third party image
Well her she is not to bad for a 1954 TO 30 ser#126XXX and it had the Howard installed also. Mark H.
gshadel
02-21-2005 06:32:54
 Re: Just got the TO 30 home with the Howard in it in reply to Willy-N, 02-20-2005 17:56:07
That's outstanding Willy!
In case I ever stumble across a Howard at an auction of junkyard... did you ned to make any drive gear mod's to install the Howard in your '30, or does it just slide right in there?
I'm guessing you had to cut a hole in the tranny housing to install the shifter... that would be a bit scary.
Willy-N
02-21-2005 07:53:10
 Re: Just got the TO 30 home with the Howard in it in reply to gshadel, 02-21-2005 06:32:54
I bought the tractor with it in it. It is a bolt on Transmission. The only holes needed are 2 or 3 drilled and tap into the inside of the case to hold it to the inside end of the transmission. I bought the tractor so I could give my freind the total rear end assembley for his and will be parting out the rest of it including the Howard and transmission forward. I will be selling the Howard with the Transmission so it will just be a bolt in assembley with no holes needing drilled. Much easier then mocking up a stock trans mission. You can allways go back to stock and remove it later but it is nice haveing the holes drilled all ready in the housing. The shifter/handle bolts right into the inspection plate hole on the side. You can see that in the picture I posted. Mark H.
John (UK)
02-21-2005 15:55:09
 Re: Just got the TO 30 home with the Howard in it in reply to Willy-N, 02-21-2005 07:53:10
The Howard gear lever is complete with the side plate, no need to driill any side plate at all.
Willy-N
02-21-2005 16:12:04
 Re: Just got the TO 30 home with the Howard in it in reply to John (UK), 02-21-2005 15:55:09
Yes the out side plate stays original but on the back of the Transmission Housing (inside) you need to drill a few holes and tap them for the Howard to bolt up to the housing. Mark H.
John (UK)
02-22-2005 09:01:46
 Re: Just got the TO 30 home with the Howard in it in reply to Willy-N, 02-21-2005 16:12:04
I am aware that you have to drill the housing as I have fitted many of these gearboxes in the past, it was just what you said in your earlier posting about the side plate that I was replying to.
Willy-N
02-22-2005 19:12:51
 Re: Just got the TO 30 home with the Howard in it in reply to John (UK), 02-22-2005 09:01:46
No problem I thought I said that also in a post befor too? Mark H.
Jake H
02-20-2005 18:36:15
whats a howard?
Barry from Stirling
02-21-2005 04:50:23
 Re: Just got the TO 30 home with the Howard in it in reply to Jake H, 02-20-2005 18:36:15
Is a Howard the same as a Henweigh????
Willy-N
02-21-2005 07:45:18
 Re: Just got the TO 30 home with the Howard in it in reply to Barry from Stirling, 02-21-2005 04:50:23
I haven't heard of one of those befor? Mark H.
Barry from Stirling
02-21-2005 08:45:23
 Re: Just got the TO 30 home with the Howard in it in reply to Willy-N, 02-21-2005 07:45:18
Morning Willy-N
Actualy they are pretty common.
Willy-N
02-21-2005 08:57:36
 Re: Just got the TO 30 home with the Howard in it in reply to Barry from Stirling, 02-21-2005 08:45:23
Since I have never heard of one what is it? Is it another type of reduction transmission? Mark H.
Barry from Stirling
02-21-2005 09:06:57
 Re: Just got the TO 30 home with the Howard in it in reply to Willy-N, 02-21-2005 08:57:36
Morning Willy-N
Forgive me, but its been a very long winter up here in Ontario and I was just having some fun. The next time someone asks you " Whats a Henweigh " just tell them around 6 pounds. Come on you haved to admit it was kinda funny? At least now I know what a Howard is.,,,,, Stay well
Barry
Willy-N
02-21-2005 09:44:42
 Re: Just got the TO 30 home with the Howard in it in reply to Barry from Stirling, 02-21-2005 09:06:57
Well you had me going til I did a Googal search. Seem I must be a little nieve because that joke has been around quit a bit!! Well at least now I know and won't get caught on that one again. Thanks, Mark H.
Ken Crisman
02-21-2005 14:09:31
 Re: Just got the TO 30 home with the Howard in it in reply to Willy-N, 02-21-2005 09:44:42
Hey Mark , do ya know what a rooster ways ? Ha ha
Willy-N
02-21-2005 20:16:30
 Re: Just got the TO 30 home with the Howard in it in reply to Ken Crisman, 02-21-2005 14:09:31
No but I did go Snipe Hunting once!! They told me to hold open a Burlap Sack and call for them! Never found any till I moved here and found out they do exsist! Mark H.
Willy-N
02-20-2005 19:38:37
 Re: TO 30 Front Weight Set Up! in reply to Jake H, 02-20-2005 18:36:15
third party image
Saw your post on a front weight for your ferguson. Here is one I made up for mine once. It bolts to the Front Axle Mount under the front end and was made out of 6 inch channel steel with 2 sections of 2" recever box steel welded to it. That way when I needed the weight I slipped in a 200 lb bumper and pined it on. If I did not need the weight I slipped in my light weight bumper instead. I made the heavy bumper (in picture) out of 6" dia solid steel and welded that to a channel that had 2 sections of box steel to slide in the the mount under the tractor. Worked great for both set ups and did not put added stress on the front axle pin being bolted to the axles that move. Mark H.
Willy-N
02-20-2005 18:45:52
There rare so you don't see so many of them. First one I saw on a Ferguson TO 30 but several on the 8Ns. It is used to slow down the Tractor Ground Speed but keep the PTO Speed the same so you can Roto-Till with the tractor. It goes between the Transmission and the Rear Differential not like the Sherman which goes in front of the Transmission. The Sherman will slow down the tractors ground speed but at the same time it slows the PTO speed, when you roto-till you need a fast PTO for the Tines but a slow ground speed to allow the tines to break up the ground better. Mark H.
Willy-N Howard
02-20-2005 17:58:15
 Re: Here is a Picture of the Howard in reply to Willy-N, 02-20-2005 17:56:07
third party image
Only the outside but this is thr real thing and it works! Mark H.
