PTO SHAFT BUSHING AND SEAL
bryan86
02-20-2005 11:49:34
Does anyone happen to know the part number to the pto shaft bushing and seal. I can not find it anywhere. This is for a ferguson te20
Vince ( FRANCE )
02-21-2005 11:54:36
 Re: PTO SHAFT BUSHING AND SEAL in reply to bryan86, 02-20-2005 11:49:34
You wrote: "this is a TE20" For the gasket used on the bearing housing,
( Sparex part # S61322 or MF part # 1075 ) for the PTO shaft Seal ( Sparex part # S.41867 or MF part # 1190 )
HTH
Vince.
Al in BC
02-20-2005 14:02:42
Bryan.The answer to your questions might be answered like this. The old number for the seal is 195-763-M1, Sleeve number is 181-183-M1. The MF dealer should be able to match this but all things not being equal you might have to machine a sleeve. I took measurments of the sleeve OD and the Housing OD plus the depth and supplied them to my bearing and seal outlet, they in turn supplied me with 2 seals. I took one and inserted with lip facing out to keep contamination out.. Then I put some grease in the cavity and then installed the second seal with the lip in so as to stop the internal fluids from getting out. Then replaced the cover. Won't let fluid out and won't let fluids in. (water and mud etc). Just my thoughts. Might be overkill but will save in the long run.
Al in BC
