TE-20...what is it?
Zippy4554
02-20-2005 06:58:00
There is a TE-20 advertised locally. Is this the English version of a TO-20? Do they have the same engine?
Where TEs imported to the US from England or Canada?
Anything to look for if buying a TE...special problems etc?
Are they more or less sought after than TOs?
John (UK)
02-26-2005 10:19:35
 Re: TE-20...what is it? in reply to Zippy4554, 02-20-2005 06:58:00
To be strictly accurate the TO20/30 is the US version of the TE20/TEA as the TE's were in production before the US started tractor manufacture and they imported TE's to fill the gap until the factory started up. The original idea was that the tractors would be exactly the same, but it was easier and cheaper and sensible to purchase and manufacture items in US than bring them over from UK so certain parts became different like Brakes,electrical,gearbox bearings, gearbox housing,clutches,steering box,eventually engines too.
jane
03-16-2005 06:15:57
 Re: TE-20...what is it? in reply to John (UK), 02-26-2005 10:19:35
did they make a te30 and if so how to tell the diffrerntthe plate behind the sterring wheel has te 37388
John (UK)
03-16-2005 08:16:52
 Re: TE-20...what is it? in reply to jane, 03-16-2005 06:15:57
No they didn't make a TE30, but they did make an equivalent model which was a TEA with an 85mm bore engine. In some parts of the world it was called a TE20/85 there were another couple of names for it which escape me at the moment. The first ones were made in 1951 and were 6volt then at 200,001 they changed to 12volt. TE on the plate does actually tell you what it is....A TE with a Continental engine. We have about 15 or more models of the TE series tractor in the UK including the original TE20 which was like the TO20, then we had engines running on different fuels so they all had a third letter to denote what it was "D" for TVO, "F" for diesel, then we had narrow tractors and Vineyard models all with different engines so the third letter told you what it was liked TEE which was a TVO engine but narrow width.TE37388 is a 1948 TE20 with a Continental engine (this was the last year Continentals were fitted @ tractor number TE48000)
Usually easiest way to tell any 85mm TE series tractor is the air intake on the dash panel (unless someone has changed the engine)
dave k
02-22-2005 13:33:30
te20 brakeshoes are toltaly differnt had to haven my old shoes relined te brakeshoes are obsolete.all other parts interchange with the to20
John (UK)
02-26-2005 09:54:09
 Re: TE-20...what is it? in reply to dave k, 02-22-2005 13:33:30
TE brakeshoes and other parts are NOT obsolete, they are readily available.
Mike Ferguson- Iowa
02-21-2005 18:06:16
All Lucas electrical parts. Brakes are different. Transmission housing is aluminum, not cast iron. Hood is latched differently. Hood dog legs are aluminum, not steel. That"s about all that"s different from a TO-20.
John UK
02-22-2005 09:41:02
 Re: TE-20...what is it? in reply to Mike Ferguson- Iowa, 02-21-2005 18:06:16
Not all the "hood doglegs" as you call them were Aluminium only a few tractors are like that.
bryan86
02-20-2005 07:42:50
It is the same thing as a to-20. it was made in england and shipped to the us. nothing different at all really
Ricochet
02-21-2005 16:10:10
 Re: TE-20...what is it? in reply to bryan86, 02-20-2005 07:42:50
What would the value of TO-20 in good condition be worth? Is there any good web sites to get older tractors current values? thanks
wayne2
03-20-2005 14:27:25
 Re: TE-20...what is it? in reply to Ricochet, 02-21-2005 16:10:10
1k-2.5 depending on lots
Jim W
02-20-2005 08:18:30
Well it will have a Lucas electrical system, and I think the brakes are different, but very close.
They were imported until the US factory got up and producing TO20s. Both have Continenetal engines.
Later in the UK they switched to engines made by the Standard Motor Company, and the gasoline model became known as the TEA20. Canada continued to import from the UK so got these instead of the TO20.
Jim
