Thanks, Nick......................................
RonW
02-19-2005 22:06:16
That is all good info and will be helpful. May try to pull it tomorrow and will likely have more questions. Thanks again, RonW
Glenn/Calif
02-20-2005 14:50:22
 Camshaft Nut in reply to RonW, 02-19-2005 22:06:16
Nick. Had to do the samething last Dec. I was able to get every thing done at my very slow pace in about 8 hours. If I were 40 years younger It would probably take 4 hours. Do be careful with removing the govener cover, the ball weights will fall out. If one or two fall into the oil pan you may be able to fish it out with a magnetic pickup. Same with the Cam Nut if it also fell in the pan. When reassembling the ball weights and retainer, I used Petrolium Jelly (Vaseline) to hold them inplace while I re-installed the weight assembly. The Vaseline will wash off in the oil and not hurt anything. Good luck.
